hupo224
- Manchester, NJ
Hi! I'm from Manchester New Jersey and I had my XJ for about 2 months now. It is a green 98 with 256,000 miles. I'm 20 and looking hard and long for a job. (fingers crossed everyday for a phone call to come). It's been a bit difficult to be able to pay for things (oil change, etc). I have a few minor (and I believe common problems) with the truck.
For one I believe a few of my bushings are worn gone. You can hear some noise when on the trails. I'm not too sure though. That is what I atleast can see and tell. (I gave it a bit of a shake down too). I have a noise that I have yet to figure out. When on the trail I sometimes here a slight rattle come from the front right of my truck.
I had to get pulled out of clay once (my mistake) and I accidentally put the tow strap around my steering stabilizer and outer tie rod. I have since then replaced the steering stabilizer and my dad "bent" back the tie rod as straight as he could. My alignment is pretty bad and pulls slight to the right while driving and to the left when braking hard. My front end wobbles (steering wheel shakes) at 55 mph+
I do believe I need a tune up. I havent been able to check my differential fluid yet. My oil is holding its place on the dipstick. And my ac does not work.
So basically I am asking any kind of help or guidance. I use this truck daily as I try to job hunt as well as see my girlfriend. Much appreciated, everybody.
