CheapXJ
- 570, 813 or 303
I need to make a circuit that takes the signal from an XJ VSS in the t-case and turns it into a signal that sweeps from 0v to 5v between 0mph and 100mph so the WJ's PCM doesn't whine about the missing 42RE (all solenoids and the temp sensors have been dummied out with resistors and the speed sensor signal is just tied to the signal output from the ABS module.
ONLY code is p1762, and it comes and goes, if I fake the gov. pressure sensor signal a little better I know it'll go away.
physical install was mostly 91 XJ parts (tranny, tcu and harness and tranny mount), used 91 XJ flywheel first, ran like crap, swapped it for a 99 flywheel and it was fine, windows on the tone ring are VERY similar, off by millimeters, and it makes a HUUUUGE difference.
stock XJ transmission shifter cable was adapted at the center console shifter using a piece of an e32 BMW hood hinge.
V8 WJ brackets were used for the transfer case shifter cable (cable came from quadratrac 4.0L WJ) made a lever for the 242 t-case by shortening a quadratrac lever.
redrilled the crossmember to fit the XJ tranny mount and then just offset the tranny mount 1/2" toward the tranny pan (made a spacer so it overlaps, yes I know, gotta drop the crossmember to change the filter, but AW4 has a drain plug, so fukk it!)
this was both a 4wd swap and a tranny swap. 2wd tranny blew up after the new head went on (0331 garbage) so it rushed the project a little.
I have notes and I should publish them, if nothing else for when I go to the parts store and forget what part came from where! :wierd:
yes, i do have a power/comfort mode switch. it is awesome. It is just as good as the aw4 ZJ I did, if not better, definitely more time consuming than the ZJ swap, ZJ 42re had a separate TCU I could rip out, but I am so close to having the PCM completely fooled. I know the 42re can act stupid and slip and not throw the CEL, so as long as I fake it, I should be good!
That's what she said :laugh3:
but seriously, my roommate is delivering pizzas in it right now. I think he's more stoked about it than I am (he did most of the work anyway, I just did the R & D)
I've been wanting to see this happen since 2006.
