Frank Z
- Colorado Springs
Been a while since I've been able to work on this thing. Took a little time away from a few other projects and made a little progress today.
Got some mounting points welded on for a Hi-Lift Jack.
Used a spare stub shaft and unit bearing hub to mount the spare. The stub shaft has had the ears removed and is welded to the cross bar. The hub is secured to the stub shaft with a hub nut. The hub serves double duty as a tire mount and trail spare.
