anothr D.W. thread
userbmx1315
Dallas, NC
my buddy just got a 96 xj with a 3" lift that has a bad D.W. hes has replaced both unit bearings an alignment and tires ballanced, what else would cause it? he has a new stabilizer and a rustys tie rod
Bad steering joints, bad control arm bushings, bad trackbar end. check everything. then search. this has been discussed 8 million times.
i kno its been covered. everything seems good, just wondering if there was something i missed
check the alignment, all my xj's and mj's(and my fsj), were all really sensitive about toe-in. get it as close to 1/8" toed-in as you can, that seems to be the "sweet spot".
what was your caster measurement? techs skip over it, and even if its not adjustable, you need to know what it is, a common dw problem is a lack of caster, as you lift the xj you can lose caster.
