XJin-AZ
- Cottonwood, AZ
89' XJ Larado 4.0 I6 AW4 np242 D30/D35< 225,000 on her
new parts; plugs, wires, rotor, cap, starter, die-electric in a lot of the connections, throttle body pulled and cleaned, and various vacuum lines replaced and ran normal after all of this.
Symptoms; starter will engage for a half second and then retract and continue to spin. I've always had hard starts, long crank, sounds of missing teeth on flexplate (none seen) but it is a little worn on the front edges, so tryed to manualy rotate the crank to a different position and the same happens, no wear what so ever on the starter(new and tested), battery is ok (took over 30 min of cranking and still no sign of goin low). delt with all that for over a year. pulled the cps to look at and the protective coating crumbled away so i have a new one to install. search didnt have any symptoms that i'm having so not sure what i should be checking. Missed 2 days of Rockfest because of this, feeling like i'm :banghead:
