I want to lower my MJ 2-3 in the front and 3-4 in the rear. Here are my plans so far. Take a TJ coil and because they are softer I can cut off some to my desired height, then because they started out softer they shouldnt be to stiff to ride on. Now the rear is where my problem is. I just installed an XJ shackle thinking it would drop it an inch but insted I got about 3/4 inch lift out of it!! Now I though about it for like an hour and firgued it out, its because the MJ is SUA so the XJ shackle being shorter just pulled the axle closer to the body thus lifting it. So I will be swaping the MJ original shackle back on. Now can someone tell me a decent way to drop the rear to 3/4 inches? I was thinking remove a leaf and also add a block as needed. Any opinions?
Thanks
Chris
Thanks
Chris
