DougJ
- Prather, CA
camarors8992: I'll try to get some pics in the next couple of days of how I routed my soft lines and what I did with the stock parking brake cables. Thanks for the complement.
Fastdemise: In those pics that I'm going to take you'll see where the ZJ soft line mount tabs are now aligned with the back of the spring perch. I'll be welding in a small square of 1/8" mild steel on there which I will drill and tap to take a screw. Then the soft lines will be nicely mounted.
The hard lines need to be shortened or replaced to make it clean, I got in a hurry and I just bent a loop in them to make them "shorter".
It works though.
