Another Dana 44 for sale thread.
VanDerKen
Norwalk, Ca.
Hello Folks, it would seem that the market has been flooded a bit with Dana 44's for sale, so I figured that I too would add to the market.
For sale, one Dana 44. Comes with: both drums, both sets of shoes, all brake hardware for both sides, full set of u-bolts, parking brake cables, 3.54 gearing, limited slip carrier, does not appear to need seals (brakes are dry and the pinion shows no leakage), u-joint straps, custom "leaky engine" rust protection, and a pair of leaf spring plates that should work with the u-bolts.
All this comes in a complete package, no assembly required.
How about $200 to start with and we'll leave the little haggle button turned on for a bit.
Got a truck and can deliver for some extra cash depending on how far the drive is. GAS AIN'T CHEAP :bawl:
That's all I have to say. Thanks for looking.
P.s. located in Norwalk 90650
Drop what ever axle you have, line up this one, tighten u-bolts, connect the parking cables, connect brake line (up to you if you want to use this one or get a new one), bleed brakes, mount wheels.
Clean it, don't clean it. The only thing that I did see missing were some of the diff cover bolts when I drained it out the gear oil.
Oobervize it's good to go.
Still have the axle?
