Pragression
- Pollock Pines, California
New XJ (new to me) overheated. Just picked it up a couple days ago been going through it performing maintenence, like i should.. except, last night on a taco bell run. She died! Overheated, even though the gauge never showed until it shut off. Pushed her home.
So this morning I start looking further into how bad the damage is and see if she will start up. Nope, cranks but wont start. Fresh battery, good fuel, fresh fluid in the radiator just in case it did start up.
So moving further, I pulled the plugs, noticed some condensation on plugs 3 and 4 but thought it could just be condensation from being cold. Cleaned and re-installed.
Tried to start again. Nope. Checked plugs. Once again, condensation on 3 and 4.
So, Im thinking its a head gasket. Hopefully the heads not cracked.
Mix all this with a rear main that leaks like a kitchen sink
( I knew about this just hadn't got around to fixing it yet.
-- so heres my main question -- if I get into the head and it is cracked, does anyone know where I can get a good motor? Haven't been to a pick-n-pull out here yet but Im worried they are all picked and pulled already. I need this up and running ASAP. I live up near Placerville but commute to the Bay weekly and was trying to make sure she was reliable, then this happened.
Any help is greatly appreciated.
