ANOTHER Beamed and Linked MJ!
That steering set up on the blue MJ is cross over steering, also known as a "swing set" steering. If you have equal length I beams, you run that style setup to get the most travel out of the front, with out binding you steering and getting bump steer. The tie rods pivot at almost the same point as the I beams themselves.
Let me see if I can find a few pictures of the whole setup.
Here's a bit better shot of it. You can see the draglink pushes on these brackets and it moves the whole thing as one... pretty simple but complicated at the same time. Big money wrapped up in that style steering in heims alone.
Photoshop is one hell of a welder :laugh3:
i dont see a stoc 2wd mj beam...all i see is a tierod
