gw204
- St. Leonard, MD
First of all let me say that the advice given by you all has been dead on every for every single question I have asked. Bravo gusy, you really know your XJs!!!! I'm getting there but have many strides yet to make.
Anyway, I was forced to take the wifew out to dinner over the weekend. We made our way to downtown Annapolis, MD in my '88 XJ, 4.0, auto w/ 209K on the odometer. As we are sitting in the midst of the BMWs, Mercedes, Acuras and other what-nots waiting to get into the parking garage, the XJ really starts getting hot. By the time we get to out space, the gauge is reading just about 240 and she (the XJ) was blowing coolant from around the overflow tank. I couldn't tell exactly where it was coming from since it was dark, the underhood light ain't worth nothin' and I didn't have a flashlight.
I spent all of dinner worry about it. We made our way home w/ normal temperatures and increases on when sitting at stop lights. As soon as we got moving again, the temp returned to normal. I am planning a full coolant system flush and refill w/ a new OEM thermostat. The radiator was replaced at roughly 175K. I also noticed that the hoses were somewhat soft so I will be replacing those as well.
My questions:
1. Since the temp goes up only at idle and when not moving, my first thought was to look at the fans (both electric and mechanical) so see if they are operating properly. What exactly should I be looking for?
2. The heater hoses going from the pump oulet (I think) are also fairly soft and old so I would like to replace them as well. I'm guessing this is a dealer only item and I should expect to pay w/ my arms and legs. Correct?
3. Since the radiator is still fairy new, I don't really want to pull it out to perform the swap to an open system yet. Can this be done using a stock radiator?
UPDATE: Just checked out the cooling bottle and sure enough, it's cracked. Can this be the cause of my problem?
Thanks again for any tips you can provide.
Brian
My questions:
Brian
