amp question
this "discount". how much is it- for the 250$ stated on crutchfield you could get 2 brand new ones off ebay through ebay stores. Which again I will echo this statement --- why would any sane person pay an extra 125$ for 1 when they could get 2???--- crutchfield has its advantages but NOT on higher priced items!! go to www.ebay.com , type in P312D4 and hit search. Cheapest price for the single sub is 122$
as for amps: my first choice would be to look for 250W (RMS) x1 @2 ohms it'll probly be listed as 500x1 but that will be peak not rms. Make sure you look for the new CEA-2006 compliance to make sure the power stated will be the amps true rms. As for powering you 6x7's whats the power rating, it is possible to do a tri-way with some amps.
well see i work at bestbuy and i get car stereo stuff a little bit above what they pay for it from the factory, so im thinkin i can get it for cheaper than 122. ( i just put the link in to show a picture) As far as the amp goes wouldnt i want to match up the rms rating on the sub with that on the amp or will i even notice it. And i think the 5X7s are rated at like 40 or 50 rms.
the sub is 250W RMS PER COIL, 2 coils, so they advertise it as 500W RMS (coil + Coil) so with what I said before, it would be matched.
If you are only getting one sub, it will look like this:
or this: but very very unlikely you would run a setup like this with a 8 ohm load on the amp
if you went with TWO subs you would have the most common set up and would look like this:
Just be sure to match the load to the amp VERY important!!
-good luck
any et anuther reminder... when you get your new subs pleeeeeze take the time to break them in. Dont throw em in a try to blow your windows out- play at low volume for a week and then have fun. The reason for this is that the spyders are coated with a type of resien from the factory- makes em kinda stiff- play at full volume the first time and you could warp/ crack them which would cause the voice coil to be outta wack and youd be very unhappy- take the time- do it right
