Aluminum Door Pocket with Cup Holder
jimmydaux
For those of you who have been interested in the door pockets I have been working on, just thought Id give you an update. Ive got the prototypes back and they look great. Bad thing is they had to do a multiple setup for the manufacturing which bumped up the manufacturing cost. Im going to eat most of that but Im still going to go forward pending sufficient demand. Just like most of you guys wanted, rounded corners with a cupholder and no hole array.
They are going to be $65 per pair plus shipping unless I am able to get the manufacturing costs pushed down a bit. I have a few areas that I may be able to shave a few dollars if things work out as hoped.
This price includes the door pocket with the edge trim installed as well as allen head fasteners for both driver and passenger sides so you can get an allen wrench in the pocket to tighten them down.
You will need to drill the plastic door panels to install these. Installation is very simple. You may even be able to install them by prying the bottom of the door panel out and not removing the panel completely. I would personally recommend pulling the panel off to install them.
Annodizing and powder coating will be available for an added cost. This price is not set in stone yet but will range from $10-20 per pair. Im working with a few providers to get this as cheap as possible. Possible colors include black, dark grey, blue, red, gold and clear. If you are interested in these, I will do some homework and get you a price. The standard finish will be a straighlined plain aluminum.
$65.00 per pair + shiping. Your total cost calculated once you give me your zip code. Send me an email at
[email protected], or pm me here to get on the list. The first run will be fairly small and probably limited to 12 pairs and will be about 2 or 3 weeks out.
They will install just like the original prototypes like pictured below ( the pocket pictured below is one of the previous prototypes and not the production model)
Looks good to me PM on the way!
