javelin401
- South Carolina
Maybe I'm out on a limb a bit as not seeing old posts for alarms but anyway, finishing up wiring in the control on my 98 4.0, and I prefer to steer clear of a starter kill as hot wiring the starter is cake on these. I've made all the other connections at or near the junct block and the system works great with way better fob range than the OEM transmitter for keyless entry.
Ive used the FSM to carefully get this far and would love to kill the fuel delivery(with a relay) but that appears too invasive, punching wiring thru the firewall and hacking into the power dist module harness. Anyone have experience on this? One alt idea would be to defeat the shifter solenoid which would lock it in park in system armed mode. This looks doable at the junct block.
I'd be glad to share what I've documented if anyone wants info on adding or upgrading a security system.
thanks!
thanks!
