Sorry to resurrect this thread, but its my turn. Unfortunately, I have no one to blame but my own dumb a$$ for this one.
So I'm at the McChord AFB hobby shop this AM to change my oil and install some 2" coil spring spacers. Too easy, right? Oil change took all of 15min, check.
Then came the coil spacers. I disconnected the sway bar, shocks, and upper control arms. For whatever reason, my trackbar bolt has a nut instead of the little threaded tab where it mounts to the axle, so I found it impossible to get a wrench in there to remove. Therefore I couldn't get the axle to drop the whole way. Instead, I used some spring compressors to get the spacers in, no sweat. Then it came time to button everything up. Reconnect the shocks, check; reconnect drivers side control arm, check; attempt to reconnect the passenger side control arm, NO CHECK. For the life of me could not get the other control arm to line up. I tried everything; even had the shop operator come help try to pry the dang thing in place; no luck. Called John (Avanteone) and it sounds like the trackbar still being connected is the single point of failure (besides an amateur trying to wrench on his Jeep). Tried every tool in the shop, nothing worked to get the trackbar bolt out. I finally realized I wasn't driving outta there and began working on a contingency plan to get my a$$ home. :flamemad:
So now I get to tow it up to John's to let him sort out the mess. Paid $36 dollars for 6 hours on the lift to fark something up that will probably take John 30min to fix.
So what do you call a n00b who reads a bunch of articles about how easy it is to install coil spacers? That's right, a n00b. :bawl:
Okay, I feel better now.
- Jay
