Matthew Currie
NAXJA Member #760
- Vermont, land of big clay
Almost certainly. It sounds like bad bearings, and even a little movement there will make your alignment inconsistent. It will tend to be more or less on center when you align it, but will toe out when you drive.Ok so I checked a few more things and then I noticed that my lower steering column shaft has a lot of play in it. I also noticed that I have play now in my spindles or something. I can now move the tires up and down like I would be checking for ball joints and all that and the only thing that moves is the spindles and checked my axle nuts and there tight and checked the 3 bolts that hold the spindle to the knuckle. It isnt very much movement but will that cause all my problems?
Play in the steering column shaft will make for poor steering control, but should not affect alignment. However, you really must track down where the play is, and get it fixed. The column shaft has a rubber "rag joint" at the top, and a plain universal at the bottom, and both can wear. The steering gear itself can wear, and develop play, especially at the output shaft. If you get someone to move the wheel while you look underneath, check for side play in the output shaft of the box. That's a common problem. A little there will not kill you but it will contribute to poor steering and a numbness on center that can make straight travel a challenge.
There are many threads here somewhere on how to get those spindles off if they're rusted on, including a very clever trick for using a long wrench socket and the power steering to push on a bolt head. Look around, and if you find nothing, post back. If the spindle is not rusted into the knuckle, the rest of the job is easy.
