I'm no expert......
However, there does seem to be some durability problems with the front ends on these XJ's, esp if flexed seriously. The Lower Control Arm bushings will split sometimes among several other things. Need to closely ck all suspension connections carefully. Believe this is the main reason for the 'Death Wobble' you see mentioned on here occasionally.
