garr
- Nassau County NY
What type of material should I use to run a line from my 200psi underhood air compressor to my storage tank mounted under the vehicle above the axle ?
X2, copper's good. Use flared fittings (preferably AN flare, not 45 degree plumbing flare or compression fittings) and plenty of PTFE on any NPT fittings and you'll be all set.
i have no idea where would i look to find out and what exactly am i looking for? its a 98 4dr sport
37 degree AN flaring is more robust and can be disassembled and reassembled without worrying about reflaring the ends or leaks. It is more expensive though... if you aren't going to disassemble it ever, or only once or twice, go for it and use standard 45 degree flaring, you won't have an issue. I would not use compression fittings under any circumstances though.Curious as to why not a 45 deg?
Stick with what you think you know!When is the last time you dealt with "circuit breakers" that operate at +2500PSI?37 degree AN flaring is more robust and can be disassembled and reassembled without worrying about reflaring the ends or leaks. It is more expensive though... if you aren't going to disassemble it ever, or only once or twice, go for it and use standard 45 degree flaring, you won't have an issue. I would not use compression fittings under any circumstances though.
Also, remember to put shutoff valves in various places if you're running locker(s) and non-essential gear off the same tank, if you don't and you break one of the lines going to a nonessential item you will be without lockers.
This morning!
Truck air brake line is fun stuff to work with, however:
Operating tempature: -65deg to +200 deg F (-54 deg to +93 deg C
A cooler is needed. If copper is not possible? what is the next option? Hydraulic hose will not dissipate much heat.
And why 200 psi?
