iwannadie
- Gilbert, Az
When I bought my compressor used, it had a crappy drain XXXX on the bottom and I replaced it with an OEM craftsman one which was great. It lasted a while and recently it started to leak and I ended up over tightening it trying to stop the leak and broke the bolt :hang: . I was thinking just replace it with the same type but that one I had was a bit of a pain. It had a threaded screw that needed turned and was a pain to get a good grip on.
I was looking at alternatives and see a lot of people use ball valves instead. I decided to go that route for ease of use and longevity hopefully.
I ordered a valve for cheap and am hoping to thread it right to the bottom of my compressor. It may be to long though and I might have to use a 90* elbow. What type of metal elbow should I look to get, I would think brass but is there anything special to look for? Since it's under 125 psi of pressure would it need to be something strong or just regular brass 90* pipe fitting?
