Aftermarket steering wheel, what fits?
Amund2
Norway
I want THIS wheel
But, here is their list of applications: http://www.ompracing.it/pdf/en/mozzi.pdf
Seems to be mostly european and japanese rally cars. My question is, is the steering shaft/spline on the XJ compatible with any of these, or is it possible to find a wheel hub from another origin that will fit both the OMP wheel and the XJ shaft? Or do you know of other wheel vendors that may have a similar wheel (this is a rally wheel with suede leather grip)? I have checked out Grant, but I didn't find anything else than fancy looking (and I admit I liked some of them) wheels, but it's the grip I'm after.
Alternatively, if someone has some measurements and a spline count for the shaft I can check stuff out on my own.
Thanks.
I can't be of any help to you, but I like the steering wheel. However, when I click on the link to the website that you put on your message I can't get to the webpage. Is there another link?
The shaft is in the neighbourhood of 3/4" with 36 splines. The adapter required to mount the Grant wheels is Grant p/n 3196. Given that and that it's a GM column, you might be able to cross-reference.
