O-Gauge Steamer
- Colorado Springs, Colorado
So, I have had a couple of PMs asking how the AEM is operating...
To date I have had Zero CEL events, my AFRs run in the mid 14s except under full boost/throttle accerations where I run it fat in the low 13s. I have Zero detonation.
I propose that we share the maps developed to help out those just starting down the path. No two of the maps will be the same, but it would give a head start to the members attempting this task.
If anyone would like a copy of my F/IC8 map, drop a line and I'll email it. Keep in mind that my frequency map is set for 4.56:1 gears and P285/75R16 tires. It would make a good start though, just correct the table for your combination. I took a stab at doing the math and was close, final adjustment was done on the hiway as tires are not always the size the manufacturer claims they are...
Be advised that F/IC6 and F/IC8 maps are not compatable.
