Adjustable upper control arms
2001XJ
Canton, MI
Looking for adjustable upper control arms. Preferably would like rubber twist joints like JKS uses to keep down noise and vibes but would consider others.
TIA
i can build you a set to spec.. using johnny joint with 1" threaded shank and a bushing at the other end.. it heas great flex and adjustability and also is great on the road. i can build a set for 150
