Adjustable Control Arms
bhicks
Forest Falls, CA
I was cleaning out the garage today and came across these. Since I no longer own a Jeep I really don't have a need for them. When I bought the used lift for my WJ a couple years back they were in the box. The seller told me he had them custom made to fix the death wobble he was getting. They are not straight but welded at an angle. He then removed his upper control arm mounts on the axle side and relocated them like 6" further in. His thought process was that it would kind of have a triangulated effect. It did work for him, but I never used them. His death wobble was due to the fact that he had the upper and lower arms at the wrong length. I dialed in the measurements and never had any death wobble. They are 14 1/2 fully in and 17 3/4" all the way out (safely). That is from center of hole to center of hole. I'm pretty sure they are the teraflex arms. They use the factory bushings at both ends. The arms get their flex by having the actual arms twist during articulation. They are the same arms I ran on my TJ and WJ and they were quiet, super heavy duty, and easy to maintain. I just greased them every few months. On an XJ the mounts would probably need to be cut off and rewelded at the correct angle. The arms new were around $250, but since they have been cut and rewelded the value kinda got killed. How about $40. If you want them shipped then I will do $50 to anywhere in socal. Name is Brad. You can call me at (909) 238-3333. I'm not on here often so either send me a PM or call me.
