ACOS Pro Air bump
tcm glx
NAXJA Member #1033
They are the sh!t... .and there is a set for sale on the So Cal forums for cheap!!
cant afford the bumps, but hey, lets talk acos...
how solidly do they mount up top? do you need cage reinforcement? and can you add cage reinforcement later?
(havent seen how they mount up top)
also, some people have mentioned having to rebuild their bumps due to the axle bump pad moving the shaft sideways during articulation, have you ran into this?
any spy shots of your ideas for your c/o setup?
where you gonna mount your new bumps?
Also, what is the cost/benfit of the ACOS Pro's vs. Custom Bumpstops with cans?
I understand the ACOS bolt right on with fabbing anything. If you weren't running coil-overs, would you guys run them on a Jeep Speed rig?
with the acos pro you can adjust the ride hight and the bump position, a weld in bump is not adjustable unless you add/remove spacers to the bump pad, and like jim says you cant run them with a coilover, i think its cheaper tho just to weld in some bumps
