Hammered
- Jeep Fiend Club
First of all - This was way easier than I was imagining it would be. Also* I want to mention I got these for $150 shipped off ebay. (private seller) IN BOX - Brand new never installed. Pretty good deal I think.
Tools needed: Cutting wheel or sawzall / grinder / tap (10mm) and some paint to coat the cut area.
**all you're cutting is the flared end that hold the rubber bump stop - no biggie. Clean up the edges til you just have the "washer" and hole exposed. Tap it. - clean up / wipe off.
**with a screwdriver pop off / slide off your stock spring retainer. Then paint the area.
& that's about it - once your paint is dry bolt in your ACOS put your springs back in and you're all done.
