i know that a trailer is deffinatly the way i wanna go here. but until i get one i was thinking about flat towing. has or does anyone flat tow? can you guys give me any advice with it? thanks dustin :cheers:
Braking is usually the main issue with flat towing. Even with a 3/4 or 1 ton truck which will usually stop okay, most states allow only about 2000 lbs to be towed without brakes. I flat tow mine behind my Winnebago, and they only allow 1000 lbs without brakes. Try www.campingworld.com for towbars and braking systems. I have the system with a small compressor in the motorhome which operates a pneumatic cylinder that presses the XJ brake pedal proportionally with the m.h. brakes. It definately makes a big difference. HTH
