jimgrms
- Oceanside Ca the beach
the big problem with the electric motor driven a/c is the extension cord
fspell220 said:sorry if I missunderstood you. now that you say "cover" your quote makes sense now about the engine cutting out and what-not. By-the-way, I don't know if you realize it or not but your caps lock key intermittently keeps sticking. Thanks for the advice.
cstilesiscool said:if you care about fuel economy, buy a honda. my jeep gets 10-12 mpg and i don't care. i don't expect it to get bad a$$ mileage.
FoMoCo said:XJs just don't get good milage period ... a vehicle with the airodynamics of a brick
Ecomike said:I average 34 mpg in my 85 Cherokee pioneer. Not bad for a brick!
Ecomike said:I see some heavy weight comments I must reply to, LOL.
" lol, no fair, you cheated and swapped in a diesel"
Yes, I cheated, but physics teaches us how to cheat so can we elliminate multiple extraneous variables and arrive at ellegant equations that define things in terms of just a few simple variables. By cheating I proved that the XJ body design, shape and weight is capable of at least 34 MPG fuel mileage. So the question then becomes one of what can we do to get better mileage out of the stock engine and transmission. I am still trying to get past 16 mpg highway, 12 mpg city with a 4X4, 87, 4.0. I have been told by dozens of other XJ owners that they have gotten as much as 25 mpg out the entirely stock 4.0 XJ's ( 2WD and 4x4s ) in a thread I started about 10 days ago here.
"Remove everything that you don't need from your Jeep to save weight. You might even want to consider taking out your spare wheel/tire and just carry a can of fix a flat."
I will never use fix a flat again. Makes it impossible to spin balance the tire, and tire shops will not repair or put inner tubes in a tire that has had fix a flat put in it.
"Using the a/c is also known to reduce mileage, so use your windows for ventilation."
I disagree, I think, on the freeway at least, that the added drag of open windows, may exceed the savings of not running the AC compressor. Just a guess, opinion on my part, but based on some experience with the top end speed of my Diesel XJ, I get about 3-5 mph higher top vehicle speed with my AC on and windows closed, than I can I reach with my AC off and windows open. I only tested this once, so I am not possitive, it could just be a wash, and could vary with wind speed and direction!!!!!! But I would not say that open windows saves gas over AC on, windows closed, at least not at highway speeds.
"Modding your intake to reduce the amount of air is a good idea to increase gas mileage, but like others have said, you can accomplish the same effect by keeping your throttle settings low. (foot out of it)"
I simply disagree with this premise. The XJ idle speed and A/F ratio is computer (O2, MAP, CTS, and IAT sensor, ECU & IAC) controlled. Any small changes in intake air pressure will be insignificant in their effect because the IAC and throttle body plate restriction control the intake manifold absolute air pressure that the engine actually sees except at WOT where the air filter and throttle body throat, and injection port diameters become the limiting factors in intake absolute air pressure.
"Drag is responsible for about 70% of all fuel needeed to move a car like XJ, it doesnt matter if its heavy or not"
Don't think I agree with this. Depends on how you define drag. Air drag varies with vehicle speed, minimal at 35 mph, more significant at 80 mph with windows open, a good head wind, and luggage on top. Internal vehicle power train friction (another form of drag) varries with engine RPM and vehicle speed, transmission gear, and torque converter lock up, or non-lock up, brakes, differentials, oils.....).
A lot of fuel is used just idling, a lot of fuel is used to overcome inertia to get the XJ moving and up to speed. MPG is '0' at stop lights, stop signs, dead non-moving traffic & during warms ups in the driveway. MPG is lousy while braking and while accelerating.
"The only time when weight doesn't matter in fuel economy is when speed is constant on flat roads."
I agree with the point you are trying to make, but lets say its less, or not significant on flat roads. The heavier vehicle at constant velocity is going to contribute more to internal friction (energy - work) losses (bearings) since it must continually over come gravity of the heavier vehicle to keep it moving at constant velocity. But I agree an extra 100 lbs on a flat road at constant velocity should not be that significant. 10,000 extra lbs would be significant.
"If your air filter is plugged or you air intake is restricted, you will have to use more throttle opening to get the required amount of air"
I agree
"...... this will cause the air velocity in your intake manifold to drop"
I agree.
"which kills engine efficiency"
Not sure I agree with this, might have an effect on efficiency, not sure its significant, except maybe at WOT.
"...... it can also skew your map readings, also not a good thing......"
Interesting thought, I will have to dwell (LOL, think) on this a bit. Possible effect I can see, but possitive or negative, don't know, would need a lot more data on the program itself, map atbles, built in ECU PCM program equations, and maybe dyno test data to convince me of the actual overall effect.
"high air speed velocity in the intake manifold and in the exhaust system are both key to producing an efficient engine"
Yes, I agree, up to a point, but I suspect there is a peak air velocity at which efficiency suffers if the velocity is forced any higher. So how do we optimise that? I take it the idea is that a certain peak air velocity is critical to mixing the A & F to get a more uniform burn, combustion. But at what point does the effect become significant for fuel efficiency, mpgs?
"....... this is why too large of an exhaust system kills low end power..... it kills the velocity of the exhaust air and hurts cylinder scavenging......"
Can you elaborate on cylinder scavenging?
Is low end power significant to fuel economy? If so how?
Everything else I agreed with (so I did not cut and past it here).
So how significant is this valve overlap, and does it exist on stock 4.0s?
So one would need to retune /adjust the ECU/PCM tables and sensor equations , or even install an adjustable MAP if one added a turbocharger that increased the intake manifold absolute pressure over the operating range in order to avoid a huge drop in engine efficiency and MPGs?
It is just too dogone hard to cram this much info that I have shared with all of you into a few short sentences...... I will try to be less of a windbag.........jeepcomjI have ceased to read the last 3 posts. they're just too darned long. I'm a windbag, and they've out-windbagged me. I'm surprised, and defeated. not from lack of intelligence, but lack of stamina to read their posts while simultaneously absorbing information.21 Hours Ago 23:24
