RichP said:
Hmmm, your name 90Red I hope that if you have a 90XJ and put R134a in it you did the conversion from R12 before hand, they do not mix well.
Rich, if by "conversion" you mean more than just pulling a vaccuum on the system, allow me to throw a monkey wrench into your thought process. My recent experience seems to agree with what four_shot is saying:
I just had my '92 changed over from R-12 to R-134a about a month ago. The system had sprung a leak and gone non-functional back in the spring.
Inquiries at the dealer revealed that the better strategy was to see an A/C specialist (their words), so I checked with the local shop, which had done A/C for me in the past on my old Omni.
Took it to him, and as it turned out the condenser (a.k.a. evap core) was shot. Seems the metal fins had all the stiffness of cardboard that was rained on the night before. Other than that, he didn't change any parts. Reportedly (and also according to the invoice), all he did was fix the leak, pull a vaccuum on the system, and fill it back up with the R-134a.
Admittedly, he may have installed the R-134a condenser, since mine was the source of my leak, but when I talked to him on the phone before taking it to him, he said you don't have to do anything except pull a vaccuum before pumping the 134 in.
It blows as cold with the R-134a as it did with the R-12.
YRMV
Rob
