A/C and Heater only blow through defroster
Dino's 99XJ
Do you think it is just the canister under or a vacuum leak going on? Is there an easy way to diagnose of fix this issue? No matter where I set the HVAC unit it only blows up high. thanks!
all the research just says check for leaks basically, which is obvious. but I was thinking what you guys said, most likely at the canister. I will check it out first and then follow the lines if no luck there. thanks
There is a common point of failure where the hard plastic line is routed by the battery.
Indeed. Battery corrosion and plastic don't play well together. I've also found that if the corrosion didn't get to that line, it's dry and will develop hairline cracks that you can miss on visual inspection. Best to remove the line to give a good looking over.
