tdicola
- Seattle, WA
Hi all, over the past couple weeks I've noticed some problems with my '99 XJ that seem to be getting worse. Here are the symptoms:
- Randomly one or twice a drive the engine will stumble or completely cut out while waiting at a stop light. Foot is on the brake and transmission (automatic) is in drive. If it stumbles I'll briefly see the RPM drop to almost zero, feel the car shake a bit, and then instantly the RPMs will jump back up to about 6-700. If it dies, the engine will cut out and I have to put it in park to restart it--it always fires right back up.
- Twice now (in just the past 2 days) the engine has cut out while driving. Once on the freeway and once going through an intersection. I'll be driving when suddenly pressing the accelerator doesn't do anything and the car starts coasting. On the freeway the engine somehow restarted itself after a few seconds. Going through an intersection I had to stop, put it in park, and fire it back up (yeah, that was not fun).
- When these problems occur they rarely turn on the check engine light. If the light does come on, as soon as I start the car back up the light is gone. I tried pulling codes but nothing is stored.
- Twice while driving on the freeway I've had random jolts while driving. It's the weirdest thing, I'll be driving at freeway speeds when the car and drivetrain will shake almost like the transmission kicked into a low gear (RPMS don't go screaming up though).
Here are a few more details about my car too:
- 1999 Jeep Cherokee
- ~175k miles
- Automatic transmission, 4 wheel drive
Anyone have ideas? I'm really scratching my head as to what the problem could be. Searching around for my symptoms show just about anything could be at fault--fuel system, throttle body, sensors, torque converter, etc. Anyone have hints on how to start troubleshooting, or experience similar problems? It's getting to the point that I really can't trust to drive the car daily. Random engine stalls while stopped are annoying, but the engine cutting out at speed is dangerous.
- ~175k miles
