EUSTON2012
- BRICK
Would a 4.0L out of a 99 cherokee sport fit into a 97 cherokee sport with no modifications? If not, then what exactly do I have to do to make it work? I appreciate your response in advance, thank you!
Some of the sensors will be a bit different and have different connectors. Of the top of my head I know that the oil pressure sender is different. Shouldn't matter though as mechanically, everything from the '97 engine will swap over to the '99 with no issues.
