99+ intake upgrade recipe
pma4x4
I would like to make sure i have this parts list correct. If i am missing anything, could some one point it out?
1996 XJ 4.0
installing and/or using following items
'99+ 4.0 intake manifold
new Edelbrock Header '91-'99 #65923
'99+ PS bracket and tensioner pulley
New fuel injectors from Precision auto injectors '96-'98
'96 original fuel rail
'96 Bored TB from the fastman
manifold/header gasket for '96 4.0
Exhaust is done. I will just have to get a new down pipe after this. Also a cold air intake is in plans during this project.
I know there is the possibility of plumbing of vacum lines and lengthening of sensor wires. I am wondering if i got it all right here
Mine were in good shape, going by appearances, but I'd read on here that they should be replaced, so I went for it- another $15 for hardware and spares seemed like cheap insurance. I don't know if it's necessary, but that's what I did.
so is it just 'bolt on' and go? all i have is the intake. no brackets or anthing. (except on my 98 when i swap the stroker)
From what Canman says and i have found it in the last few days, if you have a late '96 or newer PS bracket then yes it is a bolt on. like said before you may have to extend vacum lines and or some wires but some have and some have not so you wont know till you do it.
My header is in, still waiting on Injectors. I won the auction for the 99+ intake so that should be here middle of next week. and the TB from Fastman i may have on Saturday. Airflow Snorkel should be in late next week as it had to come direct from Australia.
Exhaust shops says they might be able to get 2.25 pipe up for a down pipe but at least i wont have that stupid clearance dent in it anymore.
I am taking pics, I may do a write up. Of course i have threatened people with write ups before.
Now this thing is on hold for another week as the guy i won the auction from for the intake just shipped it slow boat brown truck when the auction stated Priority mail. I was just reminded why i dont do ebay no more.
Nice job. I hope I can get my '01 XJ intake/PS pump/PS bracket with idler pulley on in the next couple of weeks. Not easy when you have a busy work schedule and you have another project going (1995 Mustang GT).
Went and di the test drive and gained power across the entire band but more so in higher Rs. Gas mileage is up +2. So all in all it turned out. I can actually bark my tires if I really want to.
This is been a excellent upgrade for me. I built it for more top end power for highway use as my wife and do a lot of overlanding. The end result was power through out the entire RPM range, crisper throttle response, smoother idle, easier starting and 2+ mpg gain.
