Medic22
- Lower Merion, PA
Hello All,
I have for sale my 1998 XJ. 182,7xx miles, 5 speed, 4.0 6 cyl. 4.5" lift overall. New Duratrac 33x12.5" tires. Several modifications as listed below and many NEW parts. Asking price is 3000, or best offer (Offers via Private message ONLY). This jeep does need some work, but with a little bit of time, this will make a great daily driver or trail rig. Pictures are attached to this post and are shown larger below as well.
Work/parts Needed:
-Turn signal switch (autozone part)
-Clutch work (has trouble shifting into first)
-Gauge cluster (some gauges occasionally do not work)
-transfer case linkage arm
New parts/Modifications:
Hella H4 Headlight Housing
Hella H4 High wattage bulbs 80/100 Watt
Upgraded headlight wiring
Battery Terminals
Dynomax Exhaust
Front Rotors, Pads
Front Drivers Side Axle Shaft Assembly
Front Passenger side axle shaft assembly
Tomken Tow hook brackets w/ hook (Not mounted, but included)
ZJ Wheels w/ Black paint
Teraflex Budget Boost (Front Spacer, Rear shackle) (1.75" Lift)
Rusty's 3" Lift kit (Coils, Leaf springs, Shocks)
Rusty's track bar
Rough County Lower Adjustable control arms
Rear Brake line replacement
Rusty's Steering stabilizer
Rear Hitch
Transfer Case Drop
Polyurethane Motor Mounts
Intake Manifold upgrade
Alternator
Brake drum master cylinder
Rear Drum Hardware
Rear Drum Shoes
Interior floorboards herculined
HD Lower control arm mounts (1 installed, 1 included in sale)
Cowl Snorkle
Goodyear Wrangler Duratrac 33/12.5/15 tires
Rough Country wheel spacers
Front windows tinted (all windows at 20%)
Factory front grille guard
Factory rear taillight guards
Spark plugs
K&N Air Filter
Hella Driving lights
Work/parts Needed:
Battery Terminals
Dynomax Exhaust
Front Rotors, Pads
Rusty's track bar
Rear Hitch
Transfer Case Drop
Alternator
Rear Drum Hardware
Rear Drum Shoes
Cowl Snorkle
Spark plugs
K&N Air Filter
