grasshoppa
- nashville,tn
hello everyone. Ive searched on here for a week and can not find anybody with the same problem.
98 xj 4.0 4x4
1. When the motor is cold the motor rolls over 4 or 5 times before it starts, but if you run it down the road turn it off and start it back it fires right up.
2. the jeep idles like crap. It feels like it is stumbling. It drives just fine with no considerable loss of power but at a red light I can look at my hand trembling pretty good from the steering wheel. There is no CEL light on.
I was hoping it might be the temp sensor not functioning properly . I pulled the plug wires one at a time while it was running and every plug wire i pulled it ran a little bit rougher but not much (i could still tell a diff between plug wire on and not). I sprayed starting fluid all over trying to find a vac leak but got nothing. I changed the plugs and was going to start buying diff parts but i dont have the money to chase this problem around (damn $200 bucks for fuel pump). i figured maybe someone would have a solution. thanks
98 xj 4.0 4x4
