98 Fuse panel layout
Purple
anyone has that? like a picture from the book or something...
I checked my 2000 FSM, and there are a couple very minor differences as compared to my '99. Here's the info. for a '99:
1. 25A power outlet
2. 25A cig. lighter
3. 10A Left hdlt high beam
4. 10A Left hdlt low beam
5. 10A Rt hdlt low beam
6. 5A Instr. pnl dimmer
7. 10A Left parking light
8. OPEN
9. 10A Hdlt delay, overhead console cluster
10. OPEN
11. 20A Run/Start Ignition, Daytime Running Lights
12. 10A Rear window defr., Turn Sig./Hazard flasher
13. OPEN
14. 10A Heated mirrors
15. 25A Pwr. door locks
16. 10A Rt. hdlt high beam
17. 15A Radio
18. OPEN
19. 10A Starter relay
20. 10A Trailer Tow Pkge. (in the 2000 it's 15A same function)
21. 15A Horn relay
22. 20A Rear wiper
23. 10A Rt. parking light
24. OPEN
25. 15A ABS, Climate controls, Cooling fan, Brake switch
26. 10A Airbag control module
27. 10A Airbag control module
EDIT: This is from the owner's manual, as I don't have an FSM for 1999.
the layout is also located in your owners manual. if it's the one under the hood, the cover has a layout diagram on the inside.
if you need, i can walk out to my xj at lunch and get you what you need
Thanks all;) i bought myself one of these "1980-2001 Jeep Cherokee manuals" :P Thanks again,
D.
If anyone actually has this (layout for inside fuse panel for '98), it would be of great help to me! I just bought a '98 and there are some electrical issues, but there was no owner's manual.
Thanks!
If noone has the layout, can someone with a '98 manual please tell me what fuse # is the cig lighter, the aux power (2nd cig lighter) and if there's a fuse inside for the factory fog lights?
Thanks!
Ok - here ya go. I have a 98 and just pulled this from my owner's manual...
Inside Fuse Panel layout.
Left Column top to bottom:
1 Power Outlet 25a
2 Cigarette Lighter 25a
3 Left High Beam 10a
4 Left Low Beam 10a
5 Right Low Beam 10a
6 Inst Panel Dimmer 5a
7 Left Parking Light 10a
8 Open
9 Headlight Delay/Oevrhead Console Cluster 10a
10 Open
11 Run/Start Ignition, Daytime Running Lights 20a
12 Rear Window Defrost, Turn Signal, Hazard Flasher 10a
13 Open
14 Heated Mirrors 10a
Right Column top to bottom:
15 Pwr Door Locks 25a
16 Right High Beam 10a
17 Radio 15a
18 Open
19 Starter Relay 10a
20 Trailer Tow Pkg 10a
21 Horn Relay 15a
22 Rear Wiper 20a
23 Right Parking Light 10a
24 Open
25 ABS, Cliamte Controls, Cooling Fan, Brake Switch 15a
26 Airbag Control Module 10a
27 Airbag Control Module 10a
It's a Cherokee thing... Chrysler doesn't understand !
Not to get too far off topic, but in my manual it shows fuse number #10 OPEN.
If I pull that fuse, it throws a 1491 - Radiator fan relay fault code.
Not sure what years this affects, mines a 99..
What it should look like:
PW - all posts stated 10 was OPEN. Am I missing something?
On my 99 if you pull fuse #10, the check engine light will come on and throw a 1491 code. I was going nuts trying to figure it out one day til someone posted their fuse panel...
I know it's an old post, but thanks for putting this up. I just picked up a 99 and it's got a few gremlins I want to work on and I don't feel like waiting for the FSM, and owner's manual I ordered to show up. :D
Rather than start a new thread, can someone tell me which one would be power windows on the 98? I see that locks are on a fuse by themselves (15), but no windows?
Neither my windows or locks work, and I want to start with the fuses. I'm wondering if there is a fuse on the cab for the windows or something under the hood?
