97 XJ part out and other stuff
I will take the front Doors PM sent....
im trying to be honest when it comes to the cage, im not a professional welder. the welds will hold i just would recommend that if u buy the cage just to grind the weld and re-weld. at the moment the cage is located in cary,il. i need to move it out of there plz someone by it before i have to move it or cutt it apart
as for the LCA's they were bought from Rustys offroad for a 4.5" lift
buy my stuff, i need room for my 4wheeler
as for price on cage its firm, im loosing on it already
i MIGHT sale some other items but i wont sale my aftermarket parts unless i can get rid of them all
MAYBE LIST-all parts used TWICE at cliffs, then garage kept in pieces not on rig
rubicon 5.5" coils
rubicon 4.5" spring pack
rubicon coil spacers
Rubicon long arm kit
5-mtrs that have been grooved for added traction 95% tread w/ 15R's 3.75" BS
48" high jack lift never used
Rusty's shackles 1.5"
front and rear tom woods driveshafts zerk fittings
rear hitch
2" block w/ slight angle
KN air filter
JEt chip stage 1 never used still in package
4- rustys shocks w/ boots and upper shock mount for front
rustys steering box brace
rustys OTK w/ HD track bar and mount
rustys stainless steel brake lines
rustys 3" drop pitman arm
rustys track bar brace
modified steering pump and gear box w/ redneck ram hydro assit
if i leave engine alone it has
aw4
np231 w/ slip yoke
flowmasters water pump
heavy duty radiator lines
trans cooler
engine cooler
mean green starter and alternator
live wires distributer
D30- super 30 w/ air locker and axle seals and new hubs
D35- super 35 " " and yes i know i wasted my money
also plenty of extra DOM
depending on feed back ill post prices or unless i find a new XJ then the rebuild will begin
NEW PRICES
Stock Parts
Rear Doors- $50
Rear Hatch- does not have rear wiper motor or inside interior $50
Hood $55
3 front window motors a piece $30
Seats- Front/back. gray cloth, a little dirty/surface dirt $15 a seat
Front wiper motor $20
Front Grill w/ lights and turn signals $50
spring pack- stock leafs that only have 20,000 miles on them w/ add-a-leaf, have a little sag $50 for both
Both airbags diver/passenger $100 for both
Rusty's fixed LCA's- w/ 4 new bushings and 2 new bushings for D30 UCA mounts $70 for the whole package
2 rear windows and 1 sunroof window $10 a piece
Roll Cage $500
just pulled out of jeep still together, needs modifaction
Flat Stock Steel $300
3-8' X 4' X 1/2"
Machine Package $350
23-Drills- 1 High pressure New
36-Bore bars Used but resharped
28-Endmills New
20-Bore Bars New
30-Drills-Used- 1 High pressure
7-Groove bars New
10-blanks
30-Small Endmills New
20-Endmills Used
Includes most full carbide or carbide tip, ball endmills, radius groove bars, 2 flutes/ 4 flutes, all ranging in different sizes
Header for B series Honda $250
rare hytech header 3"" collector great header for big b series setups!!
-has minor damage on bottom pipes
AFTER MARKET MODS-all parts used TWICE at cliffs, then garage kept
rubicon 5.5" coils $110
rubicon 4.5" spring pack for both $280
rubicon coil spacers $20
Rubicon long arm kit $800
5-mtrs that have been grooved for added traction 95% tread w/ 15R's 3.75" BS $700
48" high jack lift never used $60
Rusty's shackles 1.5" $20
rear hitch $25
2" block w/ slight angle $20
KN air filter $15
JET chip stage 1 never used still in package $280
4- rustys shocks w/ boots and upper shock mount for front $100
rustys steering box brace $40
rustys OTK w/ HD track bar and mount $300
rustys stainless steel brake lines $60
rustys 3" drop pitman arm redrilled for heim setup $100
rustys track bar brace $40
modified steering pump and gear box w/ redneck ram hydro assit $300
Engine/aw4/np231 as a package $1000
np231 w/ slip yoke
trans cooler
engine cooler
Axles
D30- super 30 w/ air locker and axle seals and new hubs, 1/4" LCA mounts, Modified TB mount, knuckles redrilled to 3/8" for OTK setup
PRICE CHANGE
48" high jack lift never used $40
JET chip stage 1 never used still in package $200
i have all original bolts for aftermarket parts and instructions and reciepts if need be
XJ-ARNIE- i have sale pending grill, if falls through its yours
