97 XJ part out and other stuff
goodbyeXJ
gurnee,il
Stock Parts
Doors- Front/Rear. white no rust, front doors not put together, meaning wiper motor is out and interior is off. also the switches are junk for front only. Rear doors perfect minus dirt and scratches
Rear Hatch- does not have rear wiper motor or inside interior
Hood
3 front window motors
4 rotors for D30- barely used
Seats- Front/back. gray cloth, a little dirty/surface dirt
Front wiper motor
Front Grill w/ lights and turn signals
spring pack- stock leafs that only have 20,000 miles on them w/ add-a-leaf, have a little sag
Both airbags diver/passenger
Rusty's fixed LCA's- w/ 4 new bushings and 2 new bushings for D30 UCA mounts
2 rear windows and 1 sunroof window
Roll Cage
just pulled out of jeep still together, needs modifaction
Flat Stock Steel
3-8' X 4' X 1/2"
Machine Package
23-Drills- 1 High pressure New
36-Bore bars Used but resharped
28-Endmills New
20-Bore Bars New
30-Drills-Used- 1 High pressure
7-Groove bars New
10-blanks
30-Small Endmills New
20-Endmills Used
Includes most full carbide or carbide tip, ball endmills, radius groove bars, 2 flutes/ 4 flutes, all ranging in different sizes
Header for B series Honda
rare hytech header 3"" collector great header for big b series setups!!
-has minor damage on bottom pipes
will have pic's up later today, right now no shipping local pickup only
make me an offer, no set prices yet
willing to trade for
99-04 WJ Akebono calipers W/brackets
99-04 WJ Knuckles
99-04 WJ Akebono Brake pads
99-04 WJ rotors (redrilled to 5x4.5)
located near RT. 94 and Grand Ave
how much for the grille and front doors?
$600 for the cage made of DOM, the welds need to be re-done, because it was installed inside the jeep i could not weld at certain points. will section it if you want to buy it in pieces, just let me know
Stock Parts
Front- $45
Rear- $60
Rear Hatch- does not have rear wiper motor or inside interior $50
Hood $75
3 front window motors $30
4 rotors for D30- barely used $15
Seats- Front/back. gray cloth, a little dirty/surface dirt $15 a seat
Front wiper motor $20
Front Grill w/ lights and turn signals $70
spring pack- stock leafs that only have 20,000 miles on them w/ add-a-leaf, have a little sag $50 for both
Both airbags diver/passenger $100 for both
Rusty's fixed LCA's- w/ 4 new bushings and 2 new bushings for D30 UCA mounts $70 for the whole package
2 rear windows and 1 sunroof window $20 a piece
Roll Cage $600
Flat Stock Steel $500
3-8' X 4' X 1/2"
Machine Package $350
28-Endmills New
20-Bore Bars New
7-Groove bars New
10-blanks
20-Endmills Used
Header for B series Honda $250
99-04 WJ Knuckles
also have 97 engine 4.0 I-6, i need to seperate from trans/t-case which are not for sale. the engine hasnt be run in over a (yr and an half). engine has less the 77,000 original miles. i only used synthetic oil and change the oil religiously every 2,000 miles, i also need to take off performance parts such as starter, alternator, water pump, trans cooler, engine cooler, distributor, coolant lines. but i do have all orginal stock parts to put back in place, which all work great. comes with wire harness, also radiator. will have pics tmrw $350
Do you have interior pieces and if so, what color?
Looking for the driver side female buckle, and the rear right passenger upper seatbelt part (that attaches to roof) in the agate/grey color.
the LCA's were for an 4.5" lift
Alright, since i posted and you responded i spent a $h!t ton of money so i will have to let you know
Rew'vets cost more that doctors'Ster
