97 XJ P0118 Code??
my1996xj
Cleveland Ohio
So I finally decide to do some work to my 1997 XJ today and now I am stuck with a CEL!!
Code P0118-What could cause this???
My only concern is that when I canged the oil I banged the filter past the sensor on the pass side of the block. Everything looks intact, but as soon as I was done the CEL came on.
Any Ideas??
P0118 - Engine Coolant Temperature Circuit High Input
OBD-II Trouble Code Technical Description
What does that mean?
The engine coolant temperature (ECT) sensor is a thermistor screwed into a coolant passage in the cylinder head. Sensor resistance is high when coolant temperature is low and resistance drops when coolant temperature increases. The powertrain control module (PCM) provides a 5 volt reference and a ground to the sensor. The PCM monitors voltage drop to determine coolant temperature. If the ECT reads less than freezing temp. when engine has been running for more than a few minutes, the PCM determines a circuit fault and sets this code. Or if the PCM determines the sensor resistance is out of specs, this code is set.
Potential Symptoms
Symptoms of a P0118 could include:
Very poor fuel economy
A no start condition
Vehicle may start, but run very poorly, blowing black smoke, running very rough and misfiring
Illumination of MIL
Causes
A code P0118 may mean that one or more of the following has happened:
A bad connection at the sensor
An open in the ground circuit between the sensor and the PCM
A short in the voltage feed between the sensor and the PCM
A bad PCM (less likely)
A bad temperature sensor (shorted internally)
Possible Solutions
First, if you have access to a scan tool, check the reading of the coolant sensor. Does it read a logical number? If so, the problem is likely intermittent. Perform a "wiggle" test by wiggling the connector and harness to the sensor while watching the reading on the scan tool. Watch for any drop-outs. Drop-outs would indicate a bad connection. If the scan tool reads an illogical temperature, check the resistance of the temperature sensor. If it is out of specs, replace it. If it is in specifications, unplug the sensor and, using a fused jumper wire, jumper the two terminals of the connector together. The temperature reading should now be maxed out to above 250 degrees F. If not, there is likely a problem with the ground circuit or voltage supply.
Check for 5 volts reference voltage at the connector. Also check for ground presence at the connector. If you do not have 5V ref. and/or ground continuity, check for these back at the PCM connector. If you have these at the PCM connector, then repair open or short between the PCM and the sensor. If you do not, remove the offending wire from the PCM and then check for proper voltage at the PCM pin. If it's present now, repair short on the circuit. If it isn't present after removing the wire and checking the pin, replace PCM
NOTE: Usually, P0118 is indicative of a bad temperature sensor, but doesn't rule out these other possibilities. If you're unsure of how to diagnose a PCM, do not attempt.
I got that from a search on Yahoo, the site gave me a list of codes and an explanation for most of them. I'm going through some issues with my O2 sensors, I bought a code scanner but wanted more detail.
The info there tells you the repairs that are needed to clear the code, and symptoms you may be having if you don't do the work.
Mark
Unfotunately I don't have a tool that will read that, just the basic tools for me.
you dont have a volt meter?
that is a basic tool, if you dont have one, get one. or barrow one.
I believe the sensor in the thermostat housing is the one for the computer. The sensor in the piece the oil filter screws into is the oil pressure sensor. I agree that a meter to check the resistance of the sensor is the best place to start.
