97-98 Xj Cruise Control Se Wi $150
jeepcomj
wisconsin
This is a complete Cruise control system from a 1998 Jeep Cherokee XJ. It was removed in working condition.
Includes
Cruise control clock spring (locked to center so you can install easily)
Cruise control servo, cable, and vacuum hose
Cruise air bag (necessary to swap in 1997. 1998 and up already used this air bag with and without cruise)
Steering wheel "shroud" backing
Thumb switches for cruise (suffix AC meaning 1997-1998 only)
This will fit 1997 and 1998 Cherokee XJ, and 1997 and 1998 Wrangler TJ's. The airbag, clock spring, and cruise control motor will fit 1997-01 of both body styles, but you will need switches with part numbers that end in "AD"
I have this listed on Ebay as well. The price here is lower to accomodate my brethren Jeepers.
Price is $150 OBO
I have the bare '99+ switches I could throw in a flat rate box if someone picks this up and needs them. I just did this swap on my 98 5speed and love it!
Bump. 120
I am not a hasidic nor practicing Jew, so unfortunately "Kosher" has nothing to do with me.
I won't use the phrase "bump" again. But you can bet that when I have a price adjustment, I'm going to click "post quick reply" rather than "edit post", because my new price won't be noticed otherwise.
