fishinpolejoe
- Virginia - southwest tip
I made up a set of vacuum plugs for the intake manifold a long time ago. High idle, usually around 1500-2000 RPM often means a vacuum line is broken, They don't have to break all the way, they can be cracked and the RPM increase incremental.
I cut short pieces of the appropriate sized tubing around two inches long and plug the ends with a bolt. I keep a set in my toolbox.
Don't fart around, plug them all, and see what happens. If the high idle remains it is unlikely to be a vacuum line issue.
The booster can cause high idle issues. But you will often hear the vacuum leak before it becomes large enough to be an issue, It will hiss when you apply the brakes. I've only seen it once, but the check valve for the booster can fail.
Based on a video I watched, my plan was to blow tobacco smoke into one of the lines to see if it might come out at the leak. It seems too easy not to at least give it a shot. If that isn't productive, I like your method as well. I would need a schematic to find them all though.
The intake can cause high idle issues. Especially if the idle changes as the motor heats up or cools. I periodically check my intake/exhaust bolts anyway. They do come loose. I periodically re torque mine and about half the time find some loose.
There seems to be some variation depending on the engine temperature, but a vacuum leak doesn't seem to fit the bill. I say this because:
I can get in my Jeep, start the already 210 degree engine, and it will idle at 800 rpm. I drive to a customer's house, put it in park, and the RPM's go up to 1,600 and refuse to drop so I shut it off. After the forty five seconds it takes to make my transaction with the customer I restart the engine and the RPMs are back down to at least 1,000 RPMs. I experienced this on thirteen different deliveries tonight consistently. I don't think the engine could cool down enough in forty five seconds for a vacuum leak to seal and the RPMs to return to normal. Would you agree?
Unfortunately I don't have a torque wrench. I'm due for an oil change so I will ask my mechanic to check the manifold bolts for me just in case.
That's right, I don't change my own oil. I'll gladly pay someone ten dollars over the price of oil and filter to do it when it takes them fifteen minutes and it takes me forever. They also grease it, top off the fluids, and let me know if anything looks wrong.
The TPS can cause high idle, usually way high, 3000 RPM or more. I'd be suspicious if my idle went up after getting the motor wet from splash or washing. Spray cleaner can also cause TPS issues, the TPS isn't sealed well.
I've never sprayed the engine off or driven through water more than six inches or so deep. We did get a generous amount of rain a while back.
The throttle body bottom gasket can be a problem, reusing an old seal can be iffy. The bottom of the TB rarely sits exactly where it indented the gasket the first time when reusing the old gasket, there is a little play in the mounting bolt holes.
I intend to get a new gasket when I take the TB off for cleaning which leads me to a question. Do the TB bolts require a certain torque?
Less likely is a faulty MAP, usually when they fail they often richen the motor way up, depends on how faulty they are. The programming is going to try and optimize fuel air mixture and may cause idle issues.
Even the battery temperature sensor can cause idle issues, when mine was bad (in my 96) the idle went up a 100-150 RPM or more. The same can happen with a faulty engine temperature sensor, 100-150 RPM higher because the motor stays in warm-up mode.
Battery temperature sensor? I didn't know that even existed. I put a new engine temperature sensor on it soon after I bought it along with the temperature sending unit because my temp gauge in the dash wasn't working.
Have you tried unhooking your battery cable and rebooting the computer?
Yes. I did that after cleaning the TB and IAC.
I've had good luck spraying a little penetrating oil into the IAC inlet while the motor is running, while I work the throttle a little. Four or five squirts usually cleans everything up quick, just be sure not to lose the nozzle down the TB throat (the voice of experience speaking). The vast majority of the times I've had IAC issues, my battery or my alternator crapped out completely a week or three after the IAC issues first showed up. I don't really know why, but it has happened to many times to be a coincidence.
Ohm test your grounds. Corrosion and old age degrades the ground contacts. Same with the ground crimp mounting rings.
Use the key test to see if you have any MIL codes.
I've run out of ideas, for the moment.![]()
Electricity befuddles me :confused1. I can use a test light, but not a meter. I will have to educate myself.
I will see if I can find instructions on how to do the key test.
I appreciate your ideas!
Joe
