- long branch, nj
Posting this up for a friend of mine.
1996 Jeep Cherokee
Miles: 254,XXX
Basic Specs: 5spd, 4.0l Inline 6, 8.25 Rear/D30 Front (stock gearing), 231 T-case, Manual Windows/Locks, A/C Needs rechargerd,
Lift Parts: Rockkrawler 3.5" read with AAL (Totals around 5" lift leafs), 4" Trailmaster coils, Trailmaster Control Arm Relocation brackets, T-case lowering kit, Rancho shocks (less than 2,000 miles on them), Rustys Adjustable Trac bar.
Exhaust: Flowmaster 40/High flow cat exhaust,
Un installed Extras:
TJ Flares for the rear, Hitch , Push bar, second set of Steering and a New in box set of Moogs Tie rods
New Parts:
-Clutch and Master Cylinder Assembly
-Water Pump, Thermostat/Hosing and all Hoses
-Battery, Starter and Alternator
- All Fluids (T-case, Axles, Oil, Coolant)
-Alignment
-Axle seals/wheel bearings
Issues:
-Needs two new tires
-Shift boot plastic is broken
-Drivers side seat ripped
-It's not the nicest looking jeep. The only rust on the truck was on the floors which were patched and painted
Drivetrain Runs good. Starts first crank no knocks/pings, Transmission shifts fine and doesn't stick/pop or grind. Doesn't burn oil. Leaks slightly around the oil filter (not noticeable between oil changes)
Asking $2000 Only trades I am interested in is Canon Pro quality Photo equipment
I will try to get some pics up on here and can answer a couple of questions but if interested call the owner, Dave, at 732-865-3078. Located in Belmar/Wall NJ.
1996 Jeep Cherokee
Miles: 254,XXX
New Parts:
-Alignment
Issues:
