McQue
- Plainville, Connecticut
My 2001XJ PCM causes the ASD relay to be energized by providing a ground to it ...when the relay latches up it provides power to coil...I'm pretty sure it energizes the fuel pump relay by providing a ground to it also....So...you might want to disconnect the battery, and then disconnect all 3, 32pin PCM connectors, inspect and clean them...being very careful not to create a problem...maybe gently inspect each pin with a flashlight and paper clip...on both harness and the PCM...A bad PCM input or output signal connection can hose you over...
