95 Saturn misfire
RNMedic
NAXJA Member #659
Dayton, Ohio
Okay got a cheap gas saver, it has a misfire at higher rpm with subsequent loss of power on acceleration. New plugs and wires, new air filter, got 158 k on it saturn bb recommended coolant sensor, 10 buck no change. Any suggestions?? John
sl1 or sl2?
if it's the twin cam (sl2) check the plug wires at the coil pack for corosion
checked some corrosion on coils
still loosing power 2800 rpm and up. no codes on the ecm, any suggestions??
check for vac leak at intake manifold cyl #1 is a common spot for gasket to leak
use carb and choke clean spray area while engine is running a leak will change rpm
