Disclaimer - I have searched the A/C threads and got good info out of the responses to UcilXJ's thread (here: www.naxja.org/forum/showthread.php?t=58945&page=1&pp=15&highlight=A/C) however, something's still rotten in Denmark.
Background: 1995 Jeep Cherokee Sport, 2 Door, 4.0L HO, Auto, 4wd, 67K on the clock. Sat around for about a year and not driven hardly at all.
Problem: Breath of Hell A/C - I live in Tucson, AZ. 105 outside + Wind of Hades blowing in my face outta A/C vents not acceptible.
Steps taken: Scoured
.org, bugged NAPA dudes, poked and prodded various fender-lizard acquiantances. Eye-balled little window with my A/C on and see the oft-mentioned "tiny-bublles".
A. I obtained (1) 19oz bottle Arctic Freeze R134a w/pressure gauge. I followed the directions on said bottle, to wit:
"1. Locate low pressure port and remove cap. Low pressure port is the larger diameter hoser unning between evaporator/firewall and compressor.
2. Start engine and set A/C to Max Cool. Connect charge coupler to low press. port. Check gauge. (reading 0lbs press at this point)
3. With engine running and A/C on Max Cool, shake can while holding upright. Press trigger to charge system. Relase trigger periodically the check pressure."
So...I did. I stopped and checked the pressure about every 30 secs. Finally, on the third check, I see that I am starting to to get close to 25lbs pressure. I continue. On the fifth pause and check...I see the needle drop back down to 0lbs.
I stop and check the temp coming out of my A/C vents....it's gone from Blast-Furnance to somewhere around luke-warm.
I wait a bit and see if the A/C cools down anymore. Nope.
I try again to charge the system, doing 2 applications of 30 seconds and checking the pressure. Still at 0 lbs.
Discouraged, I wave my hand infront of the vents to see if it's cool. Nope. I shut off the A/C and return to the can of R134a (still connnected to the port) where I discover the pressure gauge now reading at about 55lbs (Danger Will Robinson). I turn the A/C back on to Max Cool and check pressure. Now it reads zero. Repeat: A/C Off - Pressure 55 lbs. A/C on Max Cool - Pressure 0 lbs.
My A/C still blows luke-warm. Let it blow for 5 min while sitting stationary and went for a 15 minute drive in the early morning air while it was still cool (i.e. 88 deg). Nothing. The can of R134a seems about 3/4 full. The clutch is engaging. My little window is full of bubbles. I am perplexed to say the least.
Linky (or more accurately, URL-ly) to pics:
Pic 1 - http://photobucket.com/albums/y218/Shatner556/?action=view¤t=Picture001.jpg
Pic 2 - http://photobucket.com/albums/y218/Shatner556/?action=view¤t=Picture002.jpg
Pic 3 - http://photobucket.com/albums/y218/Shatner556/?action=view¤t=Picture003.jpg
Soooooo...wtf? I know the refrigerant is in there. Been 6 hours now and I just checked it. Same. A/C off - 55lbs, A/C on Max Cool - 0lbs. No identifiable leaks. All I can fathom is that the line is somehow obstructed or plugged.
Fire at will.
10-32
Fire at will.
10-32
