94-96 Fan bracket bearing
xjdavid1
I have a 95 XJ and I need a bearing for the Fan bracket. The bearing that was in there was a ball roller type. It had rollers 1 end and balls the other end. Does anybody know where I can get a ball roller replacement bearing for this. I have seen the NSK 885586 but it is a ball ball type and not sure if this will last. I did replace this bearing with one from Summit Racing / Omix which is made in India but it only lasted 2 years and almost took out my radiator again.
I expect your location poses the challenge for you.
A quick search by the given P/N brings up this table for me: http://www.peakbearings.com/water-pump-bearings4.htm The bearing P/N you provided is toward the bottom of the table. Can you order it from them? Or find out from them who is a distributor for Australia?
Odds are you already know this, but someone else who finds this thread later may not know: You will probably need to cut one end of the shaft off with that bearing. Our XJs don't have in impeller on the back side of this particular bearing.
