[not the main rig-so its been sitting, ive been trying to figure it out]sunk it in a creek, 4.0, 5speed, ran fine for 3 hours in the water, got it out and parked it for a while in the woods, then came back after an hour, she started right up. got it home to fix the destroyd dana 35 spider gears. put the spider gears in, and it wont start. cranks but no start.
replaced: coil, CPS, cap, rotor, wires, plugs are new, and a used computer. still crank no start
then we check the fuses and relays, switch out some new fuses for old ones, nothing. then we put a meter on the wires
no power to the fuel pump and no power to the coil. we are stumped??
i duno if this has anything to do with it but we were upgrading the rear lights and a wire hit the ground and blew the fuse to the brake lights but got it fixed.
