91 mj 2wd to 4wd
asykes
missouri
I'm thinking about buying a 93 xj for a donor but it has a auto trans and i want to keep the 5 speed in the mj will this be a problem
You're going to have to find a 4wd transmission is the biggest thing. Also you will have to either change front axle ratios or swap the rear into your MJ as well to have matching (3.55 for auto/3.07 for stick). Front driveshaft won't work without being retubed.
Basically, unless you're going to use the auto, keep looking.
Later,
Joe
thats what i was afraid of i hate to let the xj slipp away for 500 bucks no title and the motor is toast but every thing else is good
