Stumper92
- Smithfield, Va
Here's the story (I appologize in advance for the length of the writeup):
I had the Jeep at an event a couple weekends ago. The Jeep ran great until Sunday morning. When I started the Jeep that morning it idled fine. I allowed it to warm up before I moved it. As I left the campsite I noticed that the engine would hesitate a little under load. It was hesitating as if the plug wires were arching, so I figured as I drove and the moisture from the heavy dew the night before burned off, the engine would smooth out. However, as I continued to drive the missing progressively got worse until the Jeep was at a point where it would barely run. Since I trailer the Jeep to events anyway, I loaded it on the trailer and brought it home. My first guess was the fuel pump was dieing. So this weekend I connected a pressure guage to see if I am losing fuel pressure. I found I am getting about 35 - 40 psi while the engine is running. What I did notice is that as soon as I shut the engine off the fuel pressure bleeds off within 10 seconds. I connected to guage to my 94 XJ to use as a reference and found I am getting the same fuel pressure but when I shut the engine off the pressure does not bleed down. Knowing the injection systems are different (90 is a Renix and 94 is HO) my question is should the fuel pressure be bleeding down when I shut the engine off? If fuel delivery is not the issue, what else could be the problem? I tuned the engine up a few years ago and the engine has at most 100 hours on the tuneup. Any thoughts or ideas would be appreciated.
Regards.
Regards.
