90 amp HF welder help.
Swamprat
little Tijuana
yes i know its a lost cause, but it was a free welder and it works! sort of, anyways im too retarded to understand the supplied diagram. can anyone with this welder post some pictures of how the speed controller should be wired up? or can someone help me understand it? i got it for free and the guys before i had it replaced the feed motor and bypassed the speed controller. which is inconvenient to me, but again free is free. so i'd like to get it working so i can fiddle around with steelmetal work and motorizing bikes and what not.
thanks
-Ian
This is the basic one with speed control and a Min/Max switch for amperage, correct?
If you don't get info by this weekend I'll drag mine out and take a photo.
Is there a difference between the blue and the black one?
not that i've found.
anyways i have the feed motor and the brown wires that go to the ground cable and gun right. but i cant seem to figure out why the two green wires go or the blue and brown one go either. obviously they dont go together cause nothing works when i wire them up
