9" big bearing ford rear disc brakes
Status
Not open for further replies.
BRIANHO13
<- Yum Chocolate
Spring, TX
This includes the caliper brackets and calipers from a Lincoln MARK IV. The calipers look like they can be used as is but I would suggest rebuilding (or use them as cores). These are the calipers that have the integrated E-brakes.
$200 plus shipping. Located In Louisville, KY.
Extra costs you will see:
The brackets do have to be put on the shafts before the bearings are put on. and you will need rotors, to get the 5 on 5.5 I used mid 90's f150 front rotors on my set up.
Just curious, the ford f150 dana 44 rotors will bolt on after this is installed? And what about e-brake cables? I'm interested, but I don't want to be doing a lot of fabrication. Also, do you have paypal?
Status
